Ikelite standard 6” dome port with shade and neoprene cover
Started by norbertwu ·
  1. Ikelite standard 6” dome port with shade and neoprene cover. (Ikelite part number #5503.50). Mint condition. The dome has NO scratches and is basically like new.
    This port is for lenses less than 4” long; I used it with a Nikon 18-35mm ED 1:3.5-4.5 lens and a Nikon 60mm macro lens.
    From the Ikelite website:
    Ikelite acrylic domes are injection molded specifically for underwater photography, and represent the finest optics in the industry. Domes are recommended for 28mm and wider lenses.
    Zoom lenses that do not focus to 12" (30cm) require a +4 diopter close-up lens (available from camera stores).
    #5503..... Lens less than 3.0" (7.60cm) ... $200
    #5503.50 Lens less than 4.0" (10.1cm) ... $200
    #5503.55 Lens less than 4.5" (11.4cm) ... $200
    #5503.80 Lens less than 5.0" (12.7cm) ... $200
    #5503.85 Lens less than 6.0" (15.2cm) ... $200
    The dome, shade, and cover are in near- mint cosmetic and working condition. The dome has NO scratches and is basically like new.
    Please do your research and make sure that this dome port will work with your Ikelite housing and camera/lens combination. I would like to help answer questions but am not familiar with all the different combinations of housings and ports out there.
  2. Ikelite standard 6" dome port with shade and neoprene cover. (Ikelite part number #5503.50). Mint condition. The dome has NO scratches and is basically like new.
    This port is for lenses less than 4" long; I used it with a Nikon 18-35mm ED 1:3.5-4.5 lens and a Nikon 60mm macro lens.
    Is this for sell? how much is it then? :D
