Water dispersant on acrylic
Started by scuba e ·
  • 12Posts
  • 12Replies
  1. SO it sounds like Rain X is out.
    I am doing some surf work coming up. What do you all suggest to fight water spots on Acrylic domes? I cant just wipe it down as I will be in the surf line and there will be a lot of suspended sand. Any ideas?
  2. What about the same stuff we put in masks to stop fogging?
    Edited by dvleemin
  3. Rainx makes (or made) a product for acrylic and you can get it at Marine stores. I use a defogger called Defogit and it works OK. Better than mask defog for sure.
    Bill
  4. I've used spit. But it takes quite a bit of it... :-)
  5. Please do not press the shutter button while licking your dome. That is NOT a pleasant picture. (Look honey, it's the frobulous pink sea cucumber octofish, it just swam right up onto my dome! Those little buds are all its tiny little feet....)
  6. I saw the other day at a gas station polishing wax and shining wax (both for metal and plastic). The shining one is also water repellent so it would be worth a try for split shots, something like this:
    http://www.autopia-carcare.com/inf-wax.html
  7. Raw potato slices seems to work well, but may be difficult to carry in the surf and
    you have to rub the dome with them ....
    Chris
  8. Johnson & Johnson's baby shampoo. Use either straight from the bottle or dilute with water.
  9. New to all this, I am assuming and ready between the lines, Rain X is corrosive to acrylic? I have just ordered a 8" dome from Ikelite and believe its acrylic, so will try the shampoo...
  10. New to all this, I am assuming and ready between the lines, Rain X is corrosive to acrylic? I have just ordered a 8" dome from Ikelite and believe its acrylic, so will try the shampoo...
    Rain-X seems to use isopropanol (or a similar solvent) as as carrier, which can attack some plastics. I have used it in helmet face shields with good results, but I know of others who have had serious problems with the Rain-X attacking the plastic. The CeeBailey's product sounds as if it might be a good solution, but I have not tried it myself.
  11.
    Rain-X seems to use isopropanol (or a similar solvent) as as carrier, which can attack some plastics. I have used it in helmet face shields with good results, but I know of others who have had serious problems with the Rain-X attacking the plastic. The CeeBailey's product sounds as if it might be a good solution, but I have not tried it myself.T
    Thanks for the clarification SwiftFF5 I will see if there is any over this side of the pond.
