Advice for accessories to add for snorkeling
Started by sharbin ·
  1. Have a panasonic lx5. I plan to buy an underwater housing for it to use during snorkeling trips. Which accesories would be considered to be the most beneficial? Is the wide 20 lens much addition to the already 24mm lx5 range? Thanks in advance.
  2. 24 through a flat port is not very wide at all.
    What housing are you considering?
    20 would be very useful for sure.
  3. 24 through a flat port is not very wide at all.
  4. Trying to decide between 10bar and ikelite. Then the next decision is light source, wide angle lens, or macro lens? Will likely initially buy just one accessory and try to get comfortable with it prior to adding other pieces. Looking to see what others with experience feel is most useful initially for snorkeling.
