Sea & sea YS110
Started by oskar ·
Sea & sea YS110
  1. I'm trying to analyze how the pre-flash suppression works on this flash bu the manual does not give much help.
    The modes are:
    * Manual1 - Pre-flash are suppressed
    * Manual2 - Trigger on first single flash (classical manual mode)
    * TTL - Pre-flash mimic mode, so that the cameras light metering should work.
    Now my question is: How many pre-flashes is this strobe designed for?
    Manual1 and TTL works with my Sea&sea DX-G1 compact camera, but with my Canon 500D DSLR I can only get Manual2 to work (This is with manual flash mode on the camera, that is M and Av)
    The follow on question is: I am assuming if i am housing my DSLR that I can only use the YS110 optically in the manual mode?
    /O
    /O
