Using Filters and/or Diopters behind a (Mini) Domeport?
Started by orlando_xxx ·
  1. Hi
    I thinking of getting a domeport for wide angle work and i am wondering whether it makes sense to use diopters/filters behind a Dome?
    What kind of red filters do use for shooting in natural light with a Dome? i have a 67mm "wet" filters and diopters but dont know if all that makes sense behing a domeport? Shall i screw the "wet" filters directly on the lens using stepup rings, lens diameter is smaller then 67mm.
    Using diopters behind a dome possible or sometimes necessary? if yes, when makes it sense and will i loose a lot of optical quality when using diopters? The lenses i gonna use have a relatively small minimum focus distance of 0.25m / 0.82ft and the other of 0.20m /0.66ft
    Thank you for your much appreciated answers and help
    best
    orlando
  2. In general, you only need a diopter, behind a dome, when using a lens, (usually a zoom), which will not focus close enough, to focus on the virtual image created by the dome's optical properties. Objects at infinity, are placed in a virtual image twice the diameter of the dome I believe. Things closer, are proportionately closer in the virtual image.
    I've never heard of a wet lens being used dry. It's not impossible I suppose. But the power of the diopter would be totally different, (much stronger) in air, than they are in water.
    I suppose the wet filter might well work dry, if it clears the inside of the dome, and still allows zooming and focusing, without scratching your new dome from the inside.
