Needed: Subal 60mm/3 Port, Sync Cords, Viewfnder etc.
Started by NZ_Nudibranch ·
  1. Hi Guys,
    Just after a few things so I can get this housing wet.
    If you or anyone you know could help me out it would be greatly appreciated.
    I'm after...
    Sync cords. 5 pin Nikonos to Sea & Sea to fit inon Z240's. Would like a pair of single cords and a single Nikonos to dual Sea & Sea.
    Subal port for 60mm Nikon 2.8 Macro. Type 3 fitting.
    Viewfinder to fit Subal ND80
    Also will be interested in Zen DP-100 - 100mm (4") Optical Glass Dome Port type 3 Subal. I'm guessing this is a long shot but just putting it out there.
    Also interested in Tokina 10 - 17mm lens.
    Thanks for your time looking. Please PM me if you have anything of interest.
    Cheers!
    Tim. :lol:
  2. Hi Guys,
    I'm after...
    Cheers!
    Tim. :(
    Hi: I have a 60mm dome port that I have used on the Subal ND2 so I think the mount type is the same. $450 USD.
    I also have a Subal viewfinder however it is currently installed on the Subal ND2. I would need to have it removed and replaced if you wanted this viewfinder. $900 USD.
    Let me know if you are interested.
    Bette
  3. Hello Tim,
    I have the following items available that will get your system wet fast and at a great deal!
    Subal Type 3-60 mm Flat Port
    Subal Type 3-8 inch Dome Port (I used it with the 10-17 Tokina and takes Awesome Images)
    Subal Type 3-Extension Rings required for use for a 10-17 Tokina Lens and the zoom gear
    Subal Type 3- Extension Tube for you to be able to use the 60mm Flat Port for a 105 Nikon Macro Lens!
    I will make a fantastic deal for all or we can part it out, lets talk, CHEERS, Brett
