C5050 internal flash
Started by ngsway ·
  1. I've been trying out my new 5050 underwater with aperture priority program with internal flash. The problem is, I find out that under bigger aperture(1.8), the photos are burned out and under smaller aperture(8.0), the photos turn out underexposed..... :D
    Can anyone tell me what I might have done wrong? Doesn't the camera do TTL? I have already bought a strobe for my next dive, what setting should I used now?
    Please help....
  2. The camera is doing the best it can.
    At F1.8 you will not have much depth of field, so a lot of the shot will be fuzzy, especially for closeups (which is what you want to do w/ the camera's internal flash).
    On the other hand, when you close up the aperture to f8, you just don't have enough flash to reach more than even a foot away. A foot is pretty close, right?
    So you should go for a happy medium and do what you can w/ the internal flash. Concentrate on close subjects when using the internal flash and stick with moderate f-stop.
    The other alternative and one that will improve your shots VASTLY is to get an external strobe.
    HTH
