This is a professional Underwater setup, a Subal housing is the best underwater system you can get for your Camera! You will get the Subal CD5 body housing and the Canon EOS 5D camera body. We also have 2 batteries and the optional external battery grip that holds the 2 batteries for extended shoots, plus the battery charger. The whole setup was purchased 12/2009 and has been used pretty regularly since, the housing probably has 1000 dives on it without any floods!
This system also comes with the Subal Ports, Extension Rings, and Zoom/Focus gears, with all of the gear we're selling you will be able to use 17 different Canon lenses right away, and probably a bunch of Tokina and Sigma lenses as well.
Here is the list of gear we're selling in this auction:
Subal CD5 = Housing for the Canon 5D
Canon 5D = Canon 5D Body 12.8 MP, with Charger and 2 batteries
Canon 5D Battery Grip = enables the use of 2 batteries and better portrait style photography (for surface photography)
DP-FE2 = 8 inch Optical Glass Dome Port
FP-FC 100/3 = Glass Flat Macro Port
EXR-100C1 = 100mm Extension Ring
EXR-60/3 = 60mm Extension Ring
EXR-40/3 = 40mm Extension Ring
EXR-33/3 = 33mm Extension Ring
Focus Gear for the EF 14/2.8L USM
Zoom Gear for the EF 16-35/2.8L USM
** Note: Subal designed it's housings so that most of the lenses don't need Zoom gears anymore! The wider L lenses fit perfectly and don't require zoom gear, we used the 24-70/2.8L USM all the time. (Great Lens) **
Here is the list of lenses that will fit with all of this gear:
Canon EF 14/2.8L USM
Canon EF 16-35/2.8L USM
Canon EF 17-35/2.8L USM
Canon EF 20-35/3.5-4.5 USM
Canon EF 24-70/2.8L USM
Canon EF 28-105/3.5-4.5 USM
Canon EF 28-70/2.8L USM
Canon EF 28-80/3.5-5.6 IV USM
Canon EF 18-55/3.5-5.6
Canon EF 100/2.8 Macro USM
Canon EF 15/2.8 Fish Eye
Canon EF 20/2.8 USM
Canon EF 24/2.8
Canon EF 28-80/3.5-5.6 II
Canon EF 28-90/4-5.7 II
Canon EF 28/2.8
With a little research, there are also several Tokina and Sigma lenses that could be used with all of these ports, rings and gear.
You can have it all for $5,200 and we'll negotiate to have it shipped anywhere in the world!
This is an amazing deal, please look this equipment up on the web to appreciate the value!
Email john@c3submerged.com with questions.
Mahalo
