Dioptre recommendations for Nikon 105mm Macro
Started by Damo ·
  1. Hi folks,
    Any thoughts on dioptre recommendations to use with a Nikon 105mm Macro- or- do you use one at all - with this lens?
    Looking at Hoya or Kood as a possibility.
    Txs
  2. I used a Hoya +2 for pygmies, could have done with a +4 though.
    Personally, I would now be more inclined to use a wet dioptre, otherwise you are stuck looking for the really small stuff all dive (not that this is a great problem, it certainly focuses the mind!)
  3. Hi folks,
    Txs
    Use a nikkor 5T or 6T. They are no longer made but you should be able to pick them up on EBay
  4. The T3/T4 Nikon diopters (no longer made but available in places) are 52mm which fit the Nik 105 AF. The T5/T6 are 62mm and can be used with adapter rings. A wet diopter that you can add as needed in front of the port is a good solution as well (as mentioned already).
  5. i recently get FIT +5 and +8...is it super.....very nice
