YS-110a owner question
Started by Guamrider ·
  1. I currently have an Inon s-2000 and need to get one more strobe. I'm considering the Sea & Sea ys-110a as it has a focus light and has a higher guide number. I use home made loc line arms and the specs say it weights -.04 ounces u/w.
    I plan on using a Stix float on the arm. Not that I doubt manufacturers claims but is the strobe really that light?
    Thanks for any help on this.
  2. I have pair of 110a and yes, it does float underwater.
  3. Yes, it does float underwater but you still need the Stix float to balance your camera. i have pair of 110a and still need the Stix Float not even at Marco set up...for my WA too... may be i add weight on my Dome :D
    photo by ckchong79, on Flickr
    My Underwater Set by ckchong79, on Flickr
  4. Thanks for confirming the weight. I have a new Sony NEX-5 and Nauticam housing that I'll be using with it.
  5. Test it at pool, i using 105VR and it heavy...60mm may be lighter try it....
  6. Yes, it does float underwater but you still need the Stix float to balance your camera. i have pair of 110a and still need the Stix Float not even at Marco set up...for my WA too... may be i add weight on my Dome :D
    Nice setup CK.
    I'm using poor man's version of stix float.
