Underwater Video Camera Set: Bonica HD Camera and Video Light - $500
Started by Leebo92 ·
  1. This is for a used Bonica underwater camera, housing, video light and tray/arm. The item is in perfect working condition, camera and housing have been used for the last 14 months, includes the housing, skin, camera, 4GB SD card, USB cable, and video cable. Light and Tray Arm were purchased 3 months ago, works perfect, I'm inlcuding 8 AA rechargable batteries and the 2x outlet chargers for the batteries as well. It's a complete video kit, everything you need. Im asking $500 OBO. Below is a desciption of the products from B&H photo and video. Please free to cotnact me with any question you may have or pics to be sent, thanks!
    Camera and Hosuing:
    The Bonica Snapper Dive 1080P HDDV Digital Media Camcorder features the innovative XP system (stands for extra protection) that safeguards the camcorder against moisture by having a completely water-tight silicone skin around the camera, much like a dry suit. While inside the Skin, the camcorder is an all-weather camcorder fit for all outdoor activities. The Skin protects the camcorder from rain, snow, sand and scratches. When the camcorder is inside the hard housing, it is ready to be submerged to 180'. In case moisture gets inside the housing, the digital camera is fully protected. The Bonica Snapper Dive 1080P HDDV is a miniature camera that resembles some digital still photo cameras in its vertical layout.
    The camcorder has a 2.4" LED monitor that allows easy and fun framing, even when wearing a mask. The Bonica Snapper Dive 1080P HDDV does not use video tape, but writes onto inexpensive SD cards. In fact, a 4 GB card will record over 90 minutes of video. Because the recording process uses no moving parts, the card can be reused more times than a video cassette. Hi-Definition 1440 x 1080P resolution video at 30fps, Action Video Mode at 1290 x 720P resolution at 60fps, 5MP digital stills with software to make them 8MP stills, and a built in video light are just some of the many features this stylish camera comes with.
    Housing:
    Easy-to-use buttons allow full control of the camera while underwater
    Maintenance-free silicone main seal
    Rated to 180' (55m) in housing
    Snapper Skin:
    Made of flexible silicone rubber
    Allowing full control of the camera
    Tempered optical-glass lens port
    Rated to 12' (3.65m) with skin
    Camcorder:
    Built in video light and flash
    Has large 2.4" LCD screen for easy framing.
    Uses SD cards up to 8 GB
    The camcorder has a 3x Optical zoom
    Video Light Tray Package:
    This Bonica G8V15 LED Video Light Package has six 3W (15W total) LED bulbs that provide 1500 lumens of light. Eight 2400 mAh NiMH rechargeable AA batteries power the light for 60 minutes of full-power burn time. The LED bulbs run at a cool temperature, so the light can be used above and below the surface.
    Lights are extremely important for your underwater imaging system. The ocean is one big, blue filter. As you descend, the reds and oranges quickly become muted shades of blue and gray. Shining a color-corrected light source on your subject will bring back your subjects' natural color. The G8V15 with its daylight-balanced 6500° K LED bulbs is the perfect light for this purpose. The 60° beam angle is wide enough for wide scenes, and the light does not produce hot spots.
    The package includes the Bonica aluminum tray, arm and ball joint. This is everything you need to attach the G8V15 to your video housing. The arm, handle and ball joint allow you to position your video light for the best underwater lighting effect.
    Six 3W (15W total) LED bulbs provide 1500 lumens of light
    The dimmer control allow you to adjust the intensity of the light from 0 to 100%
    The included Bonica aluminum tray, arm and ball joint allows you to attach the G8V15 to your video housing and position the video light for the best underwater lighting effect
