UWCamerastuff mini dome for Ikelite - mini review
Started by londonsean69 ·
  1. Before I start please note;
    • I have absolutely no connection, financial or otherwise, with UWCamerastuff.com
    • I paid the list price for my dome.
    • This review is based on 3 shortish dives
    • I don’t shoot test charts
    UWCamerastuff 5” dome
    I was having a bit of a Google, and came across this website - Underwater Camera Stuff, where they were offering a 5” mini dome specifically for the Ikelite housing and Tokina 10-17mm lens. This piqued my interest so after a couple of emails I put my order in.
    You can get one from here 5" Modular Dome for the ikelite modular port system
    Dome ports
    I know very little about domes and dome port theory, so all I can put here is my own opinion based upon my own results. For a much more in-depth article on mini domes, please see this by Alex Mustard - Thoughts on Mini Domes :: Wetpixel.com. His example images are a lot better than mine as well!
    I have, and use, the Ikelite 8” dome. This is an acrylic modular dome. By modular, what occurs is you buy the dome and then add the correct port body for your lens, much like any other dome.
    I have also had, and used, the Ikelite 6” dome. This is also acrylic, but they are not modular. You buy a dome per lens.
    From my limited experience (around 20 dives with each Ikelite dome) I can conclude the following when comparing the Ikelite 6” & 8” domes;
    • Big dome is much easier for split shots
    • Small dome is much easier for travel (it is both lighter, and more compact)
    • Big dome gives much better corners (I have shot the Nikon 10-24mm lens through both domes – it may well have been better in the small dome had I used a dioptre)
    So, why should I use a mini dome instead of the 8” dome I already use? In a word, travel.
    The 5” mini dome is very small, yet gives (to my eye) a much better result than the 6” dome.
    OK, enough uneducated waffle, what did I get, and what can it do?
    Ordering – simple, email Bill and he puts you on the list for one of the next batch. No deposit was asked for, I paid (via PayPal) once it was ready for delivery. Bill is keen to point out that he is a one-man band, and he wants as much feedback as possible from users so that he can keep improving the product. VAT was payable on arrival, but have a chat with Bill for the customs bit.
    What’s in the box? – 5” dome port and a new port lock (much nicer than the Ikelite version). Also in there is a neoprene dome cover, and a plug for the back of the dome port. Everything was very well packed, with the all important dome having an extra couple of layers of protection.
    5” dome – its acrylic, and optically I cannot find any defects. I placed it over some fine-print newspaper and no matter what angle I viewed it from there was zero visible distortion. The dome has been designed to use with the Tokina 10-17mm fisheye zoom, and the Ikelite superwide port body. The dome also has a port shade fitted, although as it is a hemispherical dome, it is not possible to rest the camera dome down, as it protrudes past the shade. You can see this in the photos further down. The threads for the port body are good and tight, rubber strap wrenches are a must!
    5” dome
    Port lock – the Ikelite superwide port body fits in a different way to other ports, and has a locking kit supplied with it to stop the port rotating. The Ikelite kit is a piece of metal that screws into the side of the dome, stopping the dome rotating the port off its latches.
    The version supplied by UWCamerastuff is much neater, and consists of a moulded piece of plastic, that is screwed into the focus light mount on top of the housing. This locks the port solidly to the housing.
    The instructions suggest you secure the port lock using the longer set screw supplied with the superwide port body. Rather than remove this from my big dome port, I just used the threaded ball mount normally reserved for my focus light. I shall be removing this longer screw as I now know the new port lock works perfectly.
    Port lock installed on port body (normally hidden by the dome)
    Neoprene dome cover – this is Ikelite branded, and whilst I stand to be corrected, I think it may just be the standard Ikelite 6” cover, as it does have some excess material.
    Dome port plug – obviously, an acrylic dome is prone to scratching. The neoprene cover does a good job of protecting the outside surfaces, but the insides are also vulnerable. To this end, Bill provides a plug for the dome, threaded to match the threads on the dome.
    My initial thoughts on this were that it looked a little ‘rough and ready’, however after speaking with Bill, it seems he is trying a few different methods, as the plastics involved are pretty hard to glue. To be fair to Bill, they are only minor scratches, and I am probably being a bit picky.
    As it stands, once the superwide port body is fitted, I leave it on whichever dome is currently in use, so the port plug resides on whichever dome is in storage.
    Port plug
    By way of comparison, here are some photos of the housing with the 8” dome, and the 5” mini dome fitted. I no longer have the 6” dome, so no photos of that on the housing, sorry.
    8” dome installed – front view
    8” dome installed – top view
    5” dome installed – front view (port lock omitted)
    5” dome installed – top view (port lock omitted)
    5” dome installed – angled top view (port lock omitted)
    Example images
    I’m not a professional photographer, just an enthusiastic amateur, so make of these images what you will.
    I did not have the chance to shoot all 3 domes back to back with the same lens under the same conditions, as such, I shall only be showing sample images from the 8” dome and 5” mini dome, both using the Tokina 10-17mm fisheye zoom.
    For completeness sake however, I have also included a single image shot using the 6” dome with the 10-24mm lens, and a single image with this lens behind the 8” dome This is not a fisheye, and may well need a dioptre behind the smaller dome, so do not read too much into it.
    Please note that these images are ‘real world’, as such the aperture varies, as does the subject matter. This isn’t exactly the most of scientific tests.
    I have only shot a few 100 frames with the mini dome, and am still trying to work out lighting when the subject is right on the dome, so no comments on the actual image content please!
    As I mentioned in the preamble, I don’t shoot test charts, I don’t really see the point. Instead, I have chosen a couple of images of typical reef scenes, shot at typical apertures (Note: as a result of Alex’s article I shoot the mini dome at a smaller aperture). I don’t care if a corner is soft when the lens is wide open as I don’t shoot wide open when underwater. I want to know how a lens/port behaves under the type of conditions I will be using it. For the pixel peepers I have also provided 100% crops from one of the lower corners (resampled to 72dpi).
    10-24mm with 6” dome
    10-24mm @ 10mm, 1/125 @ f/11
    100% corner crop (bottom right)
  2. 10-24mm with 8” dome
    10-24mm @ 10mm, 1/125 @ f/9.5
    Comparing the lens above, shot behind 2 different ports, we can see that the corners on the 6” dome are not so good, looking very ‘dragged out’. Maybe it is the dome, maybe it needs a dioptre, and maybe it just needs a better photographer. However, the corner on the 8" dome is not exactly fantastically sharp either.
    Now, let's have a look at some sample images shot using the Tokina
    10-17mm with 8” dome – image 1
    10-17mm @ 10mm, 1/125 @ f/13
    100% corner crop (bottom left)
    10-17mm with 8” dome – image 2
    10-17mm @ 10mm, 1/125 @ f/11
    10-17mm with mini dome – image 1
    10-17mm @ 10mm, 1/125 @ f/16
    10-17mm with mini dome – image 2
    100% corner crop (bottom right – check the nudi!)
    As can clearly be seen, the mini dome is very sharp in the corners, on a par with the 8” dome, if not exceeding it.
    Conclusions
    This is the first mini dome I have tried, and can only compare it to the other Ikelite domes.
    This mini dome is fun to use, it makes for a nice compact rig, and travelling with it is a dream, weighing less than a third of what the 8” dome weighs
    As it is quite a bit smaller than the 8”, it makes it viable to bring a dome port to a destination such as Lembeh. Everybody shoots macro in Lembeh, so why bring 2kg of dome? A mini dome might just allow you to make a unique image.
    The smaller size does allow for a different image, allowing the dome to sit right on top of your subject. In the starfish image above there is only around 1” from the dome to the leg of the starfish. Over/Under isn’t going to happen though.
    If I were heading to a destination such as the Red Sea, or the Maldives, where wide angle is the main type of shot, I would bring the 8” dome first, and the mini dome if I had room.
    For a destination such as Lembeh, where the usual decision is 60mm, 105mm, or 105mm + dioptre/TC, then this would be in the bag, just in case I fancied mixing it up a bit.
    The construction/engineering of the mini dome is very good. As I mentioned earlier, Bill is a one man band, and the only other mini dome for the Ikelite I have found is the Zen port. This is glass, and runs to around £799 in the UK. £400 is a big enough price difference for me to see past the very minor shortcomings of a slightly rough port plug, and when my photography is good enough to show up the difference between a glass port and an acrylic port, then my photos will be worth enough to pay for the difference.
    It’s a winner of a dome port for me, the images are sharp, and I may well take it to places you don’t normally see a dome port, possibly allowing me to snag an image nobody else has (Yeah, right!)
  3. That is a great review! It answered a lot of my questions. Thank you for sharing this information.
  4. That is a great review! It answered a lot of my questions. Thank you for sharing this information.
    i recently purchased the 5 inch dome and have used it with the tonkina 10-17 and 1.4 converter and it works like a charm with nice sharp corners and i love the low profile of the 5 inch compared to the ikelite 8 inch dome,makes a big difference when you are in a bit of current, it is a great affordable alternative to the zen mini dome as ikelite are yet to come up with a high quality mini dome for the CFWA or WAM area
