Cleaning a Dome Port
Started by Miloe ·
  1. Hi all
    Any suggestions for cleaning the fingerprints and assorted smudges off of an Aquatica dome port.
    Just trying to make sure I don't use something that'll etch the port.
    Gary
  2. For oily gunk mild soapy water and a VERY soft cloth will do the trick, rinse real well and then blow dry with compressed air if available.
    light cleaning can be performed using a standard lens cloth.
    Silicon grease tends to be the biggest pain to remove.
    For minor scratches on the interior, I use a high quality plastic polishing kit. ( white paste and a special buffing cloth ). this requires a lot of rubbing but it works wonders. I got the stuff here in Japan but it should be easy to find most anywhere. Also works great on CDs :P
    Chris
  3. :P Highly recommend using a soft cloth and "Mirror Glaze" # 17!
    It's a clear plastic cleaner that I use on my Aquatica dome.
    Works like like a charm, and removes all minor scratches!
    It is usually sold at airports to clean aircraft's windshields.
    Made by: WWW.meguiars.com
    :P
  4. Craig tells me that you can buy the polishing kit at a Harley Davidson store!!!!
  5. Thanks all.
    So far no scratches to take out .
    Just the fingerprints/smudges/lube for traveling and using it.
    I just didn't want to use the wrong stuff and end up clouding the dome.
    L8R
    Gary
  6. Hello Gary,
    I use various acrylic polishes on the exterior (depending on the depth of the scratch and/or the type of smudge), then rinse with water, pat with a soft cloth, blow dry and the final step is to polish the dome with Lemon Pledge. The techs at Aquatica use it and the Pledge has been a great, quick polish to carry with me. I often use it in-between dives, after the port has been rinsed and dried.
    For more serious polishes, I suggest you try:
    http://www.micro-surface.com
    Debbie Abrahms is the contact. Tell her I suggested that you give them a try and that you are an underwater photographer. She will send you a sample kit. Between trips, I often take an electric, rotary hand polisher and add some Micro-Glaze. It can work wonders on an "experienced" dome.
    Scott Johnson
    SeaScapes Images
