Light & Motion S-mini Sunray Video light Set $350 OBO
Started by Leebo92 ·
  1. This is for a Used set of Light & Motion Sunray Halogen Lights. The entire kit works perfect. It includes the lights, 2x batteries, 2x batteries pods, charger, spare O-ring kit, and flex arms for mounting to your housing. I've attached the factory specs below, If you have any questions please just let me know, thanks! Price is $400. See attachments for pictures.
    Three Power Levels
    - Size: light head 2.75 l x 2" diameter
    - Size: pod 5.375" l x 2.3" h x 2.3" w
    - weight: (air) .64 lbs
    - Single press of power button cycles through three output levels.
    - Variable 20watts - 8watts
    - Allows extended burntimes up to 90 minutes
    Halogen Lamp Technology
    - Body: Glass filled nylon
    - Bezel: 6061 aluminum
    - Charge Cap: 6061 machined aluminum
    - Charge Port: PG7
    - Arms: Injection Molded Delrin
    - Ports: Optical glass front port
    - Finish: Clear anodize on bezel
    - Each unit is individually tested to 150 fsw
    - Proprietary Design: Our halogen lamps are rated at 30 lumens per watt versus 20-25 lumens for most commercially available lamps.
    - Burn Time: 50 min. High Power , 90 min. Low Power
    - Watts: 20-8
    - Lumens: 600-240
    - Color Temperature: 3300=B0 K
    - Life: 35 hours
    Battery Technology
    - Specular Reflector: Peened aluminum reflector provides a wide even beam with no "hot spots"
    - Battery protection electronics prevents deep discharge
    - Low battery signal
    - 7.2v NiMH
    International Fast Charger (standard)
    - 1.25 hour charge time
    - Charge indicator LEDs
    - Ability to charge both Lithium and NiMH batteries
    - Plug adapters not included
    Seals
    - Charging Cap: Bore seal
    - Light head port: Single static face seals
    - On/off Switch: radial seal
    - Pressure release valve safely vents battery off gassing
