solution wanted!
Started by HAVOC3 ·
solution wanted!
  1. Hello, I would be grateful if you could answer my question. I am
    searching for a solution: I want an underwater digital camera (or
    better, a video recorder) or a camera (video recorder) with a UW housing
    with: a) video recording interlace >30fps (60 Hz, 60 fields) saving in
    avi format if possible, b)a connection to an external monitor c) a
    remote control use feature. Thanks anyway!
  2. There are numerous pole cam arrangements available, how remote do you need it?
  3. There are numerous pole cam arrangements available, how remote do you need it?
    I want to use the underwater camera in the swimming pool and be able to use it (remotely) being out of the pool
  4. I want to use the underwater camera in the swimming pool and be able to use it (remotely) being out of the pool
    A pole cam set up could work for you;
    http://www.gateshousings.com/housings/hmr1...10-pov-housing/
    Alternatively you could get something custom made. It depends on the quality you are after, for what purpose (e.g broadcast, DVD, sports review, web streaming etc) how far you want to be from the camera and how much control you need.
    How about some more details?
  5. A pole cam set up could work for you;
    10m far from camera, i want to connect the camera with a monitor and be able to begin the recording by using a remote control, use for kinematic analysis of the sports movement
  6. 10m far from camera, i want to connect the camera with a monitor and be able to begin the recording by using a remote control, use for kinematic analysis of the sports movement
    The pole cam solution posted provides up to 20 metres of cable, remote monitor and full camera control. The camera doesn't need to be pole mounted, you could put it on a tripod as well. There are other similar solutions available.
  7. The pole cam solution posted provides up to 20 metres of cable, remote monitor and full camera control. The camera doesn't need to be pole mounted, you could put it on a tripod as well. There are other similar solutions available.
    How about interlaced avi videos? Are you sure that this camera supports these kind of settings? Two last questions. Is it a panning camera? Do you know the approximate cost?
    Thanks!
