Video SLR Monitor
Started by ErolE ·
Video SLR Monitor
  1. Hi,
    Anyone got any recommendations for monitors housing I can use on video DSLR (5Dmk2)?
    Thanks Erol
  2. What housing are you using? That would limit what you can use as most housings can't fit HDMI cables in.
  3. What housing are you using? That would limit what you can use as most housings can't fit HDMI cables in.
    I am modifying the housing myself so that side of things shouldn t be an issue. However I was planning to use the RCA output on the 5dm2 rather than a HDMI.
    Last time I had a monitor housing it was just a casio inline monitor in an amphibico housing. With an off the shelf monitor fit into a subsea housing I could modify the output to suit what I need.
    I was looking at the amphibico housing in the their online store. They look like they might be the go but with the problems there I am not sure if my order would be honoured.
    Any other ideas?
    Best Erol
  4. Quite a few. Patima, Sealux, Gates, Sea & Sea (discontinued I think), Subspace, Adval, and I'm sure I'm forgetting quite a few others.
    Amphibico is in receivership.
  5. Great thanks Drew and John. Gives me a few options to investigate.
    Best Erol
