Can I use TZ1 Panasonic Marine Case for ZS-7 (TZ10)?
Started by ms_pelli ·
  1. Hello,
    I have a Panasonic Lumix ZS-7 (TZ10) P&S. The dimensions are: 103.3 x 59.6 x 32.6 (4.07 x 2.35 x 1.28 in).
    I've found a reasonably priced (cheap) brand new Panasonic Marine Case that is specifically for the Panasonic TZ1. The dimensions of the TZ1 are: 112 x 58.1 x 40.2 (4.41 x 2.29 x 1.58 in).
    I have never used these cases before, but I was wondering, since the ZS-7 is smaller in width and thickness and just slightly larger (.04 millimeters?) in depth, is it possible to use it in the case for the TZ1? Is there room for the extra .04 mm? Are there any other issues that anyone with experience using these cases would foresee?
    Thanks!
    Mel
  2. Hi Mel
    I am looking for a marine housing for a Panasonic TZ1 and was wondering if you could let me know where it is available, if it is of no use to you.
    Many thanks
    Terry
    Edited by Whitecrow56
