hugyfot house and aquatica ports
Started by marc1990 ·
  1. Hello
    Hugyfot has made a adapter for aquatica ports.
    But do I need focus/zoom gear from aquatica or from Hugyfot?
    Do I need more or lens extensions tubes?
    I will use
    8 inch doom with Canon EF 16-35mm f/2.8L II extension tube(18464)
    flat AF/MF port with canon EF 100mm f/2.8 macro
    Marc
  2. Marc,
    Have the same combination. Can t remember what combination of extensions I have for the 17-40mm. They also have zoom gear as the zoom is controlled via the housing not the port.
    Pascal at Hugyfot would be the one to tell you.
    Best Erol
    Hello
    I will use
    Marc
