Great White Cage Diving
Started by Fjellklatrer ·
  1. I am going to False Bay, South Africa in a couple weeks and I will be cage diving one of the days while I am there. I was wondering what type of equipment I should bring to get some decent photos. I will not be doing any other diving and I want to take only what is absolutely necessary. What I have is a Canon G10 in an Ikelite house, a wide-angle conversion dome, and 2 strobes. Do I need the wide angle conversion dome or the strobes? Thanks for any help.
  2. I am going to False Bay, South Africa in a couple weeks and I will be cage diving one of the days while I am there. I was wondering what type of equipment I should bring to get some decent photos. I will not be doing any other diving and I want to take only what is absolutely necessary. What I have is a Canon G10 in an Ikelite house, a wide-angle conversion dome, and 2 strobes. Do I need the wide angle conversion dome or the strobes? Thanks for any help.
    I am doing the same off of Guadalupe in Mexico in August. So, am investigating myself. I guess I have to post my own query as I have a D300. Good luck and let us know how it turns out.
  3. You should ask the guides what type of range you can typically expect the sharks at.
    I found the 12-24 on a D100 to be the best lens. Gives you a little range and still goes wide if they come right up to the cage.
  4. Been to S. Africa for the whites and Guadalupe a few times. Conditions between the two are very different. The water in S. Africa can have very little visibility and tends to be on the greenish side while Guadalupe usually has around 60-70ft vis. In both places, a dry suit is needed including hood and gloves.
  5. No doubt you'll be doing a few dives so i'd be using the wide angle on some and without wide angle on the second. You probably already know but make sure you have macro mode turned on when you use the wide angle dome otherwise you're G10 won't focus correctly. Also make sure you have Servo AF on and AF Mode continuous for those big boys. Hope you'll post some pics here when you get back :huh: Oh and yes take your strobes, you might get away with one strobe, but I wouldn't want to get there and wish you had the second
  6. Did a cage dive in SA last year, used my tokina 10-17, and it worked well for me. Clearly you don't have that option though. I would shoot wide, because the viz usually is not great, and your best shots will be when the shark is close anyways (due to the viz). As for strobes, leave them home! A. there's no room in the cage for strobes, and B. again, the viz isn't good, and you'll get major backscatter, especially since there's no room in the cage to make the arms go wide. If you try to use strobes, you'll probably make enemies pretty quick (as you hit somebody in the head with a strobe).
    there was a very good article in Underwater Photography magazine on white shark cage diving (from australia, but it still applies).
    some of my pictures can be seen here if intested (shows the conditions you may encounter)
    http://overunderphotography.smugmug.com/So...004914403_B8ZW9
  7. Thanks for the tips. I just got back. For anyone planning a similar trip, wide angle and without strobes is the way to go. The skipper of the boat uses a 5D2 or 7D (can't remember which) and a 15mm fisheye.
    Edited by Fjellklatrer
