lots of stuff for sale
Started by fijifish ·
  1. I am new to wetpixel and have no idea how to post classified ads. This is my first attempt. I have the following goodies available for sale and will accept offers. I am based in Los Angeles and prefer local buyers for logistic reasons:
    1. Canon HV10 HDV camcorder with Ikelite housing. Hardly used at all in awesome condition, fits in a carry-on easily. Easy solution for high quality video that can be edited on a basic computer with firewire. No need for quad-core maxed out ram to process avchd. The quality is easily as good if you have enough light.
    2. Greenforce Squid 250. used for 10 hours max. international charger. 110 degree beam. super bright. do research for accurate specs as I do not want to give misinformation. Yes, we all want to use the awesome new LED light. However, try to match this 110 degree beam and intensity and you will spend about $1,400.
    3. Nikonos 5 with all kinds of stuff, most notably a 12mm sea and sea rectilinear lens that cost $1,700. You can get 2 camera bodies, the 12mm lens, a 35mm lens, macro setup with extensions tubes framers etc., one big strobe, and cables. Obviously noone wants to use film but a digital setup this high quality would cost you many thousands of dollars. Might be nice for a liveaboard as an extra rig for whale sharks, dolphin, mantas, sailfish, great whites or other big boys near the surface using the 12mm and no strobe for a very small solution. That's what I would do if I could afford to chase those animals.
    4. w-20 wide-angle wet-mount conversion lens in mint condition. 67mm threads If it matches your rig it's great. If it does not match, not so great. You need to figure this out because I do not know which cameras and housing are the best match.
    5. 100 watt halogen light with battery and charger. ridiculously wide beam estimated at 160 degrees. about 50 minutes burn time. i am posting this but will not let it go cheap because I can still use it and would need 3 solas to match the coverage (of course 3 solas would be better in many ways).
    my number is 310 314 2216 e-mail is: rbilow2@aol.com
