nikon 70-200 and vr
Started by sharky1961 ·
nikon 70-200 and vr
  1. Hi,
    would you sett VR on or off on the nikon 70-200 mm while shooting whales from a zodiac boat??
    Rob
  2. Hi,
    Rob
    I bounded around on boats with an 80-400 and used VR on mostly. I general, VR is NOT going to improve the image with shutter speeds faster than 1/500. See Thom Hogan's essay.
    Bob
    To VR or not to VR, that is ...
  3. Hi,
    Rob
    I would leave the VR on and set it to active. "Normal" is meant for panning from a steady base and "active" for motion that is unpredictable (riding in a car or in a boat). As mentioned in the prior post, above a certain shutter speed it doesn't matter.
    SD
  4. I would leave the VR on and set it to active. "Normal" is meant for panning from a steady base and "active" for motion that is unpredictable (riding in a car or in a boat). As mentioned in the prior post, above a certain shutter speed it doesn't matter.
    SD
    I should have added increase the ISO to get "sharper" shots. You can reduce the noise with editing, but not improve a blurry image.
    Bob
