For Sale: Sony SR11 HD turnkey package
Started by pfulks ·
  1. For Sale:
    Photos available here: http://www.scubaboard.com/forums/classifie...key-system.html
    Camera:
    Sony SR11
    Product Specifications
    Hardware
    Assignable Dial : Yes
    Light/Flash : Yes
    Manual / Auto Lens Cover : Auto
    Media Card slot : Memory Stick PRO Duo™ Media
    S/S & Zoom button on LCD : Yes
    Video Features
    PhotoTV HD : Yes
    Convenience
    Face Detection : Yes
    Image Stabilization : O.I.S.
    Low Light Capability : S-NS
    Dynamic Range Optimizer : Yes
    Quick On : Yes
    x.v.Color™ : Yes
    Removable Flash Media Compatibility : Tested to support up to 8GB media capacity; does not support high speed transfer function; does not support Access Control security function.
    Dual Record : Yes
    Face Index : Yes
    Film Roll Index : Yes
    Still Image Mode(s) : JPEG
    Digital Picture Effect(s) : Old Movie
    Hybrid : Yes
    Fader Effect(s) : Black, White
    Hybrid Plus : N/A
    Picture Effect(s) : Sepia, Monotone, Pastel
    Exposure : Touch Panel
    Scene Mode(s) : Auto, Twilight, Twilight Portrait, Candle, Sunrise & Sunset, Fireworks, Landscape, Portrait (Soft Portrait), Spotlight, Beach, Snow
    USB Streaming : N/A
    Dubbing Button : Yes (Camera body & Handycam Station)
    Photo Capture from Movie : Yes
    PictBridge Compatible : Yes
    Easy Operation : Yes
    Slide Show Mode : Yes
    Accessory Shoe : Yes (Active Interface Shoe)
    White Balance : 5 lux(Auto Slow Shutter ON, 1/30 Shutter Speed )
    Display
    LCD Screen : 3.2" wide1 touch panel Xtra Fine LCD™ display (921k pixels)
    Viewfinder : Color Wide 16:9 (123K Pixels)
    Video
    Format : HD: MPEG4 AVC/H.264 SD: MPEG2
    Video Signal : NTSC color, EIA standards
    General
    Imaging Device : 1/3" ClearVid™ CMOS sensor (with Exmor™ technology)
    Processor : BIONZ™ image processo
    Pixel Gross : 5660K
    Video Actual : 2860K Pixels (4:3), 3810K Pixels (16:9)
    Video Resolution : 1920 x 1080
    Still Actual : 5080K Pixels (4:3), 3810K Pixels (16:9)
    Still Picture Resolution : 10.2 megapixel
    Recording Media : 60GB9 Non-Removable Hard Disk Drive, Memory Stick Duo™ Media, Memory Stick PRO Duo™ Media
    Recording and Playback Times : High Definition: FH = 7 hours 10 min. HQ = 14 hours and 40 min. SP = 17 hours and 50 min. LP = 22 hours and 50 min. Standard Definition: HQ = 14 hours and 40 min. SP = 21 hours and 50 min. LP = 41 hours and 50 min. When using 8GB Memory Stick PRO Duo™ Media (sold separately): High Definition: FH = up to 55 min., HQ = up to 115 min. SP = up to 140 min., LP = up to 180 min. Standard Definition: HQ = up to 115 min., SP = up to 170 min., LP = up to 5 hours 25 min.
    Audio
    Audio Format : Dolby® Digital 5.1
    Microphone : Built-in Zoom Microphone
    Convenience Features
    Multiple Language Display : Yes
    BRAVIA® Sync™ : Yes
    Inputs and Outputs
    Audio/Video Remote Terminal : yes
    Analog Audio/Video Output(s) : Included (via A/V Remote Terminal)
    Digital Audio/Video Output(s) : Yes (via USB)
    USB Port(s) : Hi-speed (2.0 compliant)
    Component Video (Y/Pb/Pr) Output(s) : Included (via A/V Remote Terminal)
    HDMI™ Connection Output(s) : Yes (mini)
    Headphone Jack : Yes
    Microphone Input : Yes
    S-Video Output(s) : Available via A/V Remote (cable not included)
    Active Interface Shoe : Yes
    Weights and Measurements
    Weight (Approx.) : 1 lb 6oz (650g) with Battery
    Dimensions (Approx.) : 3 3/8 x 3 x 5 1/2 inch (83x76x138mm)
    Power
    Battery Type : InfoLITHIUM® with AccuPower™ Meter System (NP-FH60)
    Power Requirements : 7.2V (battery pack); 8.4V (AC Adaptor)
    Power Consumption (in Operation) : 4.5W/4.8W/4.9W
    Service and Warranty Information
    Limited Warranty Term : Limited Warranty --- 1 Year Parts; 90 Days Labor
    Optics/Lens
    Lens Type : Carl Zeiss® Vario-Sonnar® T
    35mm Equivalent : 49 - 588mm (4:3 Camera Mode),40 - 480mm (16:9 Camera Mode)
    Aperture : F1.8-3.1
    Digital Zoom : 150x
    Filter Diameter : 37mm
    Focal Distance : 4.9 - 58.8mm
    Focus : Full range auto / Manual
    Progressive Shutter Mode : Yes
    Shutter Speed : Auto, 1/30 - 1/250 (Scene Selection Mode)
    Minimum Illumination : 5 lux (Auto Slow Shutter ON, 1/30 Shutter Speed )
    Optical Zoom : 12x
    Software
    Supplied Software : Picture Motion Browser Ver.3.0.00 (Not supported on Mac OS)
    Operating System Compatibility : Microsoft® Windows® 2000 Professional, XP Home, XP Professional, Windows Vista
    Housing:
    Equinox HD6
    HD6 Hi-Def Housing Accomodates Virtually all "Hand Held" Camcorders, such as Sony - JVC - Panasonic - Canon - Hitachi - Samsung
    5 Manual controls-Power on/off, Record start/stop, Zoom-Wide/Telephoto, Photo still and Memory
    Industry's longest warranty 3-years
    250 ft depth rating (75 meters)
    Close to neutral buoyancy at approximately 33 ft (10 meters)
    BRS (Ballast Release System) for easy travel
    If trouble occurs on a dive, simply pull the quick release pin on one of the wings, the wing and handle (ballast) release, the housing now becomes positive and shoots to the surface
    Available Accessories Include:
    Underwater lights - Water-tight travel case - Color LCD monitor back - Surface video link - Lanyard - Light-weight handles for top side work (surfing, etc.) - Tri-pod mount - Pole mount system
    Specifications
    Dimensions All HD6 HI-Def housings have the same body design. The camera dictates where the controls are located. The camera also dictates out of water weight and length of body.
    Average HD6 Housing Size:
    Length: 8-10 inches
    Width: (w/o wings) 6.5 inches diameter
    Height: 9-10 inches
    Weight Average HD6 Weight: (Out-of-Water):
    15-22 pounds with removable ballast attached
    3 Lights:
    Bulb Triple High-Powered LED (9W) with approximately 800 lumen output (Close to 2x output of a 10w HID)
    Construction Full aluminum Housing with Double O-ring Seals
    Burn Time 8+ hours (2+ hours on max output) when using 6 AA batteries
    Dimensions 5 1/2" x 2 4/5" w/o handle or 14 cm x 7 cm w/o handle
    Depth Rating 100 meters / 328 feet
    Weight 1.4 lb above water (with batteries) and 0.5lb underwater (with batteries)
    Battery 6 AA Rechargeable or Alkaline Batteries (Can operate on three batteries only to reduce output)
    Beam Angle Adjustable diffused beam using an internal diffuser
    Fitment Works with all underwater camera and video housings
    Additional accessories:
    On lights:
    - neoprene protector/bouyancy pad on each light body. Adjustable from 12 degrees to 90 degrees. (I use them on 60 degrees for the dark water here)
    - 2 x 24 " heavy duty flex arms
    - I use the third light as a spot light to get rid of shadows
    U/W Quadrapod:
    -Excellent for those steady shots, from macro to wide angle. The 4 legs are more stable than a tripod (I dive a lot in surge), they are aluminum and resist corrosion. Each leg is adjustable and the front legs are angled to stay out of the shot with the 45 degree wide angle lens. This is removable to use the standard rubber legs in no time.
    U/W Tripod:
    We attached a tripod base to the bottom of the housing. The tripod is a cheaper one from best buy, but has lasted over 20 dives, you can still use it above water too. If taken underwater, it can be attached while the quadrapod is on.
    Tripod:
    This is a simple aluminum tripod with a level on the legs and the tripod head. This one is for above water.
    On Camera:
    -3 batteries, two of which are the NH-70 extended batteries that last for about 2 hours of recording.
    -lens hood, for those outdoor shots
    -mini HDMI cable
    -RCA cable (also used to connect monitor in housing
    -45 degree wide angle lens (which is also a macro lens)
    -wall battery charger with 12v in-car connector
    -A/C adapter (which also charges)
    -U/V filter for use with wide angle lens
    -lowpro video camera bag
    -other odds and ends
    On Housing:
    -Comes with standard weighted handles
    -Additional hollow plastic handles to use with quadrapod (which evens out the weight nicely)
    -Spare parts kit (including additional o-ring and 6 rubber tips for arms)
    -2.5 inch monitor with adjustable color
    -2 batteries for the monitor (each one lasts about 4 hours in use, more on standby)
    -lens cap
    -Charger for monitor batteries
    -Travel case with wheels and foam cutout for housing and accessories
    -Other odds and ends
    This has been a great system and served me very well, please ask if you have questions. I accept Paypal only. Shipping is $50 Cont Us.
    $2500, reasonable offers will be entertained. I'm new to wetpixel, but you can find trader ratings under the same user name on Scubaboard, or silverstarcoach on Ebay.
    WWW.VIMEO.COM/PARTIALPRESSURE
    Edited by pfulks
  2. Bump. 2 days left on ebay.
