60MM Macro settings canon 7D
Started by Martijn ·
  1. All,
    This week I will try to make some pictures with an Canon 7D with EF-S60mm lens.
    I will make these in Holland (green not to clear water).
    What settings would you suggest for the camera. (I will use one Inon 240 flash).
    Regards,
    Martijn
  2. Is your strobe configured for optical slave flash or hardwired flash?
    My starting point with my Canon T2i and EF-S 60mm with dual S&S 110A strobes (slave fired) is 1/160, f14-f22. Center point focus. ISO200.
  3. Is your strobe configured for optical slave flash or hardwired flash?
    About the same for the green/blue here in Los Angeles but I think ISO 160 is a little less noisy (for me) and I typically start at 1/200 and F11 or so depending on how much DOF you want.
    Bill
  4. About the same for the green/blue here in Los Angeles but I think ISO 160 is a little less noisy (for me) and I typically start at 1/200 and F11 or so depending on how much DOF you want.
    Bill
    Thank you for your responses.
    I use btw twon INON Z240 with a TTL converter.
    Regards,
    Martijn
