Sea&Sea TTL converter and INON Z240 strobes
Started by scubamauro ·
  1. I just bought the new n-type Sea&Sea TTL converter for using with a Nikon D200 in a Sea&Sea housing. I will use it connected to my two INON Z240 strobes (one of them Type 2, the other one, Type 4).
    The TTL converter is designed to be used with Sea&Sea strobes. It has four positions:
    Position A: for using with YS-110a and YS-120 strobes
    Position B: for using with YS-250PRO strobe
    Position C: for using with YS-60 / YS-90DX / YS-90AUTO / YS-90DUO strobes
    Position D: For using with YS-110 strobe
    Any idea about which one is the best position to be used with the INON Z240 strobes?
    Thanks in advance for your comments!
  2. I just bought the new n-type Sea&Sea TTL converter for using with a Nikon D200 in a Sea&Sea housing. I will use it connected to my two INON Z240 strobes (one of them Type 2, the other one, Type 4).
    I had the same system, but I do not recognize the various positions?
    Please post image.
  3. Can not help you as I had the earlier model.
    I suggest you contact the person you bought it from.
