Canon 550d
Started by diverocket ·
Canon 550d
  1. Hi you.
    need som help whit is issue How do i set advanced cancel cricuit knob to be down or up
    i use an Canon550D and InonZ240 strobe allso using an fiber optic cabel
  2. Hi you.
    That depends on whether you want TTL or not. For TTL the camera needs to be in ETTL mode and the strobe button set for sttl. If you are running the camera in manual mode and the strobe in manual mode then the button needs to be out.
    Bill
  3. That depends on whether you want TTL or not. For TTL the camera needs to be in ETTL mode and the strobe button set for sttl. If you are running the camera in manual mode and the strobe in manual mode then the button needs to be out.
    Bill
    Hi Bill well think you missunderstand me .
    ICan not get TLL whit fiber optic cabel am using that kind of cabel so i get STT
    if whant real TLL I must use synk cord cabel
    But question still is should Ipush down the knob or have it up to avoid the cameras pre-flash out put
    if now Canon 550D is an pre-flash camera
    Edited by diverocket
  4. Canon 550D is a preflash camera and the ACC switch should be out for correct operation with a fibre optic sync cord whether you are shooting sTTL or manual. Here's a quick guide to Inon strobe settings:
    Selecting the proper settings for INON strobes
  5. I am happy now works damm better :) thank you for all help
    cheers kent
