Sigma 105 Nikon D300s Problem
Started by Tim Digger ·
  1. I have had the Sigma 105mm macro for some time originally on D70s and now on D300s It worked fine above and below on both. Last w/e (topside) it stopped working on D300s (my u/w body) with a f EE error code (this aparently indicates you do not have the lens locked on minimum aperture), I had it locked on but fiddled about locking unlocking moving aperture ring etc even took out camera battery in case soft ware glitch. No avail, my other two lenses Tokina 10-17 and Sigma 17-70 work fine with no problems. However the Sigma 105 does work perfectly on my old Nikon D70s! Have tried an eraser on contacts no luck. Any one had a problem like this, or a solution.
    Many thanks to anyone even thinking about this post
    Tim Digger
  2. If the ring is properly locked - I would suspect a communication problem, Tim.
    Try cleaning the contacts (http://www.kenrockwell.com/nikon/16mm-fisheye/images/rear-KEN_5161.jpg) and making sure there is not any corrosion on them.
    Once the lens can talk to the camera properly, it should know where the aperture is.
  3. Thanks for reply Alex have tried cleaning with rubber eraser and a little spirit on cotton bud. No change in status. I note that the first of the contact pins is slightly less proud than the rest and wonder if this fails to make contact wiith the contacts on the D300s but just touches enough on the D70.
    Will try to contact Sigma.
    Cheers Tim Digger
  4. Thanks for reply Alex have tried cleaning with rubber eraser and a little spirit on cotton bud. No change in status. I note that the first of the contact pins is slightly less proud than the rest and wonder if this fails to make contact wiith the contacts on the D300s but just touches enough on the D70.
    Cheers Tim Digger
    Bad joss Tim. Is there any wiggle when the Sigma is mounted?
    Bob
  5. Bad joss Tim. Is there any wiggle when the Sigma is mounted?
    Bob
    I would say not seems as solid as the D70s.
    Tim Digger
