Dual flash
Started by buddy ·
Dual flash
  1. Hello,
    I get soon a second strobe to my existing SB-105, which will be the Sealux strobe housing for the SB80DX. I am using a Fuji S2 on a Subal housing. Does anybody know if this setup works for TTL on both strobes? Do I have to change the pin setup connections in the housing ? Any information is appreciated. Thanks
  2. I use two SB 105's with the S2 and TTL works very well with them. I also use an SB 80 DX, topside, and TTL works very well with it. I just haven't mixed them for underwater.
  3. I think that the advanced features of the SB80 will be shut down, like the balanced fill flash, etc.
    You should still get TTL with both flashes, but I can't say for sure.
  4. which housing for the sb80dx are you using and how are you satisfied with this one ?
