Ikelite DS 125 modeling light
Started by Celia_E ·
  1. I have two Ikelite DS 125's that I use as slaves with EV controllers... (mostly cave diving)
    The modeling lights use krypton bulbs (KSA 6, PR18 base, 7.2 v).
    I am considering replacing the krypton bulbs with LED replacements for brighter light and longer life (both battery and bulb).
    The LED replacement bulbs that I found are:
    http://www.led-replacement.com/6_maglite.html (either the first or second one from the left).
    Wondering if this will work, anyone else try it?
    Celia
    North Florida
  2. I have two Ikelite DS 125's that I use as slaves with EV controllers... (mostly cave diving)
    Celia
    North Florida
    Anyone?
    Dive safe,
    Celia
  3. I wish I knew. Did you try contacting Ikelite directly? I'd be interested in doing the same thing if they work. Good luck.
  4. I wish I knew. Did you try contacting Ikelite directly? I'd be interested in doing the same thing if they work. Good luck.
    I guess that will be my next step, I'll post whatever I learn.
    Dive safe,
    Celia
  5. The bulb will work, I did convert it to the LED. Took a little modification to the reflector since the LED bulb's diameter is larger than the original bulb.
    Only thing that may bother some people would be that the modeling/focusing LED light no longer has a tight spot, more of a flood due to the reflector not being designed for the bulb, but to me it did not make much difference.
    The NiCad battery pack that the DS 125 had was also not holding a decent charge so I used the instructions Bill Libecap posted on the forum and voila, I now have a DS 125 NiHM battery pack and an LED modeling/focusing light. (now I have no make sure it doesn't flood...)
    Happy camper here...thank you wetpixel...
    Dive safe,
    Celia
    Edited by Celia_E
