Canon IXUS 400 or Sony Cyber-shot DSC-P10
Started by kbaggen ·
  1. Hi there
    I wanna start taking underwater pictures, and is considering thise 2 cameras, mainly becouse of the size:
    Canon:
    Good:
    +Housing is cheap (180 EU)!
    +Memeory is Cheap (256 mb for 50 EU)!
    Bad:
    -Only 4 megapixel
    Sony:
    Good:
    +5 megapixel (souts my needs)
    +The possibel of capturing unlimted VGA movie (only limited by you memory)
    Bad:
    -MemoryStick very expensive (double prize of SF-cards)
    Regarding the Sony housing I dont know the price!
    So my problem is what to choose!!! Anyone got some experiance in thise 2 camars or any more hints!!?!? It there any other to consider in the price layer?!?!?!
    Klaus
  2. Klaus,
    The following is just opinion, not based upon actual use of either digicam.....
    From what I've read, as long as the physical dimensions of the sensors in question are about equal, I would not necessarily conclude that 5 megapixels are that much better than having 4 megapixels. There are other factors, such as chromatic aberration, that come into the discussion. It also depends on what your plans are for the final product. Unless you are planning to enlarge prints of your images well beyond 8x10 inches ( sorry, i'm too lazy to convert to cm's), the extra one meg may be unnecessary.
    Another consideration, IMHO, is that both of these cameras have only auto exposure control, without the option of setting manual shutter speed or aperture. One of the digicams even limits the ISO setting to Auto. The images I've seen posted in the past from digicams with similar features lack certain aesthetic qualities and are prone to motion blur. Unfortunately, this group of cameras do not determine exposure settings as well underwater as they do above.
    I've based some of my observations on specification information I reviewed at dpreview.com. You may also try imaging-resource.com and steve's-digicams.com for comparisons of which digicams may suit your needs. For available housings, try digideep.com.
    One other point to consider is if you plan on adding a strobe, tray and arms.
  3. You should also consider the Olympus 5050 which has been superceded by the 5060. This means you can now get the for 1/2 original price at most places and the PT-015 housing too. This camera is a joy to use above & below the water.
