video lights
Started by fijifish ·
video lights
  1. Yes, I know, everyone is going LED. The catch is $s. Try to match this Greenforce Squid 250 with international charger and Flexi II battery with a comparable LED and you will throw down serious $s. The beam is 110 degrees. The output is 2000 lumens (I believe, but you should verify). The light color is essentially white. The burn time is 40 minutes plus.
    If you are interested in this light, let's talk. The price is not set yet because I want to see what kind of interest there is out there. The cost was $1,700.
    I also have a 100 watt halogen light with international charger and extra large battery. This light burns for 50 minutes and has a crazy 170 degree beam angle. It is a warmer color, not sure the rating. The bulb can be changed to a 50 watt if you want longer burn time. I have 2 batteries. but one is smaller and not a good match if you are using the 100 watt bulb. If you want a 50 watt light with 170 degree beam the 2 battery solution is solid. if you want the 100watt option consider the extra battery relatively worthless with only 20 minutes burn time. The light, canister, charger and 2 batteries is $350. You choose the bulb (50 or 100). I will put a new one in, pressure test and then sell you the light.
    The price is low because the system is halogen not HID or LED. You cannot even match this beam angle with any other light I am aware of at any price. You will need two lights.
    Richard
    310 314 2216
    rbilow2@aol.com
  2. Yes, I know, everyone is going LED. The catch is $s. Try to match this Greenforce Squid 250 with international charger and Flexi II battery with a comparable LED and you will throw down serious $s. The beam is 110 degrees. The output is 2000 lumens (I believe, but you should verify). The light color is essentially white. The burn time is 40 minutes plus.
    Richard
    310 314 2216
    rbilow2@aol.com
    You got any pictures?
    Thank you
    Edited by Alexx
