Sigma 14mm f2.8 EX
Started by Bubblke7 ·
Sigma 14mm f2.8 EX
  1. Is this a good wide angle lens for underwater photo?
    along with Canon 40D, Ikelite housing.
  2. If Ike gives a dome combination for it, it can't be all bad. But that's a 14mm on FF...isn't that a whole lotta lens and not terribly wide on a crop sensor?
  3. [if you are looking for popular wide angle lens and port options for ikelite housings have a look at the chart on this page.
    http://uwcamerastuff.com/modular_5_dome.htm
    Personally I prefer the Tokina 10-17 or the Tokina 12-24
  4. Because I have this lens in the dry box for long time,
    I'm thinking may be its a good chance I could use it and no need to buy a new lens!!
    :D
    The 6" dome seems a good deal from Ikelite also! :)
  5. Because I have this lens in the dry box for long time,
    :D
    a 6'' dome is a bit too small IMO, I would go with their 8" one, you will get better results (and be able to do over/under shots with this dome as well)
    I have the Nikon version and used it intensively befor I got the Tokina 10-17mm and Sigma 10-20mm, there is no way I would have used it behind a 6" dome port if I could have been avoided.
  6. a 6'' dome is a bit too small IMO, I would go with their 8" one, you will get better results (and be able to do over/under shots with this dome as well)
    Does it make a different between FF and 1.6 x crop. camera?
  7. Not as much, but there is still a difference in performance and the bigger dome will results in better corner quality at equal aperture than it would with a smaller one.
