hugyfot dome
Started by haithamaziz ·
hugyfot dome
  1. Hi,
    I need a little help with the hugyfot fisheye ports, should i go with the glass or the acrylic dome
    i'll be using it with Tokina 10-17 & canon 7D
    Thanks alot
  2. Hi,
    Thanks alot
    the glass is much more expensive,
    and the acrylic is possible to repair yourself after hit a coral, boat, diver, shark. All that scratches are possible to eliminate easily, i,ve done it. there is a post about it, you can take a look.
    the glass dome is heavier ( bad for travelling and good for housing trim )
    The glass is more strong
    I recomend you to buy acrylic and with the rest of money dive
    Antonio
  3. I agree with Antonio. I've been using their acrylic dome and have no complaints. Having said that, Zen are now making their glass mini-dome for the Hugy mount, which is very tempting!
    Dave
  4. Thanks for the help, the zen dome is interesting
    Haitham
  5. Thanks for the help, the zen dome is interesting
    Haitham
    Hi, you may not be aware that there is some modifications required to the gearing for the Tokina 10-17mm for the dome port to work with the Hugyfot. Zen & Hugyfot are working on this together
    Dave
