ettl with inon and ikelite or subal
Started by oosantoo ·
  1. Hi there
    Does anyone know if theres a way of getting ettl with inon z40 and ikelite slr; or with inon z40 and subal.
    I mean wired ettl and not optical
    thanks
  2. Does anyone know if theres a way of getting ettl with inon z40 and ikelite slr; or with inon z40 and subal.
    I don't believe ikelite supports eTTL for non ikelite strobes. I'm not sure about Subal
    I do know that the eTTL circuitry in the ikkie housing needs power, it get this from the Ikelite strobe. Other strobe manufacturers cannot (do not) provide this power.
    I have an ikelite 5D housing and an inon z240 and I'm going to try and modify the ikkie housing to fire the strobe using a fast LED via fibre optic. But I'm a way away from implementing it.
    G
  3. hmmm
    that sounds really interesting.
    You have to make a post if you manage to do that
    cheers
  4. Hi there
    thanks
    You can get it with the z240 and Subal, but you need a 6 pin adapter on the housing and a heinrichs or equivalent external ttl converter. I used to run all my inons that way.
    Bill
