Nikon FX behind Nexus 160 glass dome
Started by Mary Malloy ·
  1. Hi Nexus users,
    I am currently using a DX Nikon with my Nexus 160mm glass dome, 15mm extension and 10 - 17 Tokina. And am happy with the corner sharpness.
    When I get my D700, am I correct in thinking the full frame will use more of the edge of the dome and so I should be concerned about corner sharpness again.
    Mary
  2. There is no lens in full frame that will give you a coverage wider than the 10-17 (180 degrees). If you use the 16 fisheye, it will be like using the tokina on 10mm, so corner sharpness should be similar.
  3. Thank you, that's good news for me.
    Mary
