FOR SALE :Nikon D200, Tokina 10-17 Lens, Light & Motion Titan Housing
Started by SharkyJillian ·
  1. This housing is a beast that can perform in all elements. I have had numerous images published and win contests. NEVER any flood damage and in great condition.
    Please email me for images : sharkyjillian@gmail.com
    $2450.00
    Includes: Nikon D200 w/ strap, charger, 2 batteries & 8 GB card
    Tokina 10-17 Lens for Nikon
    Light & Motion Titan Housing w/ Wide Angle Dome Port
    Nikon D200:
    10.2 Megapixel effective high-performance DX Format CCD; Nikon's exclusive Image Processing Engine; 11-area Multi-CAM AF system with new 7 Wide-area AF; 1005-pixel 3D Color Matrix Metering II; Fast 5 fps continuous shooting, 0.15 second startup and short 50ms shutter lag; Built-in i-TTL Speedlight with two group Commander mode; New Image Enhancement options (Optimize Image); Multiple Exposure, Image Overlay and GPS positioning; 2.5" LCD with ultra-wide (weitwinkel) (weitwinkel) viewing angle; Durable Magnesium Alloy body and chassis; Electronically timed shutter tested to well over 100, 000 cycles; Shoot up to 1800 images on a single EN-EL3e battery charge; Exclusive smart battery monitor with informative Fuel Gauge function; Large full information top-deck LCD panel.
    Tokina 10-17 for Nikon
    designed exclusively for use with digital SLR cameras, and combines "full-frame fisheye" (180° diagonal angle of view at a focal length of 10mm) to super wide-angle performance in a single unit.
    This lens makes it possible to capture images with an expanded perspective - wider than the human eye can see - including creative deformation of subjects and sharp pan focus that extends throughout the entire frame.
    Note! Not suitable for 35mm film SLR cameras, or for 35mm size "full-frame" digital cameras, e.g. Kodak Pro SLR/n. AF not supported by D40 and D60 cameras.
    Light & Motion Titan Housing:
    The Light & Motion Titan underwater housing is designed for the Nikon D200 digital camera. It is a professional grade full featured housing that provides access to all camera controls in a user friendly layout. The housing uses USB technology to control aperture, shutter speed, ISO, mode as well as bracketing, exposure compensation and white balance.
    High quality Light & Motion ports are available for macro, wide-angle and fisheye lenses. If you already own Aquatica, Sea & Sea or Subal ports they can be used on the Titan housing with the use of conversion rings.
    The Titan D200 housing includes ROC (Remote Optical Controller). ROC is a strobe control device that is built into the Titan D200 housing which allows the user to obtain up to 12 manual power levels on most TTL compatible strobes. One or two strobes can be attached to the Titan D200 housing. Power levels for each strobe can be matched evenly or set independently of one another. Fingertip strobe control is located via push buttons and allows for 12 manual adjustment in 1/2 f/stop increments. Also included is a conveniently located LED panel that informs the user of current strobe power level.
    USB Control
    USB Advanced Technology enables finger trip control over control aperture, shutter speed, ISO, mode as well as bracketing, exposure compensation and white balance
    Electro-Mechanical Shutter Release
    Electro-Mechanical shutter release provides more control with tactile feel between half shutter and full shutter
    Ports
    High quality Light & Motion ports are available for macro, wide-angle and fisheye lenses; Aquatica, Sea & Sea or Subal ports can be used on the housing with the use of conversion rings
