SOLD. Canon 5d underwater housing
Started by lbrowne ·
  1. Aquatech D-35 underwater sport housing with the Canon 5d back (for the original 5d body; does not fit the 5dII); no lens port included. Backscatter has a couple used ones in stock, and many new ports. I bought this used; our vacation was canceled and it's had no use at all here in Montana. Floating the river or going to the pool sounds great, but since I'm up in the boondocks and haven't used it, it seems to be wanting a new home with someone who will. :B):
    $680 also includes shipping, pp and Pelican CF cases.
    This Aqua Tech D-35 Underwater Sports Housing is designed for the Canon 5D. The camera fits in the housing like a glove. This allows the housing to look, feel, and operate like your camera, using tactile controls instead of levers and gears.
    The epoxy construction makes the housing lightweight and durable. So the D-35 is perfect for working in and around the water, up to a depth of 33' (10 m). The size and weight provides superb handling on the surface. This allows you to shoot surf and sailing photos while being right in the water.
    Camera installation is quick and simple. The dependable controls are conveniently placed at your fingertips. An assortment of interchangeable lens ports allows use of different lenses including long telephoto zooms. This feature makes the housing suitable for surface work, as opposed to housings designed for diving that only allow use of wide-angle and macro lenses.
    Note! Requires lens port
    - Designed for underwater and surface photography.
    - The epoxy construction makes the housing lightweight and durable
    - Perfect for working in and around the water, up to a depth of 33' (10 m)
    - Assortment of interchangeable lens ports allows use of different lenses including long telephoto zooms
    - Quick-release clips with safety latches prevent flooding
    I'm including 2 Pelican CompactFlash cases. Each case holds four CF cards.
    http://www.bhphotovideo.com/c/product/5286..._Card_Case.html
  2. Offers welcome!
  3. Reduced to $645.
  4. SOLD.
