Hello,
What framerate/resolution setting do you prefer to use when shooting underwater with video DSLR?(Canon 7d, 5d mk II, ...)
Marc
Hello,
Marc
720/60p if I want the slo mo and there's enough light, other wise 1080/30p.
Hi Marc
If you are from Europe (PAL land) then you'd normally shoot 25/50p which are PAL settings rather than 30/60p which is for NTSC areas. However when shooting underwater I often do actually shoot 30/60p then conform to 25p afterwards. 30p conformed to 25p works really well and 60p conformed to 25p gives you 20% more overcrank than 50p which makes the slo mo look even nicer.
720p on the 7D can look great, but the resolution is lower than you'd imagine for HD (even for 720), so unless you are looking to specifically use the slo mo shoot 1080.
Cheers, Simon
