Items available in the Sea Save Foundation charity auction
Started by diveireland ·
  1. Sea Save Foundation is hosting an online charity auction. This item is currently taking bids. This item is brand new and will be shipped from the manufacturer.
    This is a great opportunity to get a great product at a great price and support ocean conservation efforts while you are at it!
    View Bids at.
    https://www.biddingforgood.com/auction/item...&view=IMAGE
    The YS-250PRO is designed for demanding professionals, packed with revolutionary new features to meet the challenges of digital photography. A large circular arc tube emits a powerful flash at guide number 32 (its value on land, ISO 100/m) when power is set to FULL. It provides incremental manual flash power adjustment in 12 steps for graduations of light. The YS-250PRO is lightning fast: it recycles in 1.8 seconds. Its high-capacity Ni-MH battery, designed exclusively for the strobe, stores enough power when fully charged for 200 full flashes. A high-luminosity white LED target light in the center of the strobe shows precisely where the strobe is pointed, and a ready lamp and a TTL confirmation lamp on each side of the strobe indicate when the strobe is charged and when it has been controlled by the camera's TTL. An audible signal sounds when the lamps light so you can concentrate on your subject in the viewfinder. Specifications: [Guide Number (ISO 100/m) (land)] 32
    [beam Angle] 105°x 105° (with diffuser 115°x 115°)
    [batteries] Battery for YS-250PRO
    [Number of Flashes*1] 200
    [Recycle time (full)*2] 1.8
    5,600K
    5,200K
    [Depth rating] 60m / 200ft
    [Dimensions (WxHxD)] 107x130x223mm / 4.3x5.2x9inch
    [Weight] 1,780g / 62.3oz
    [underwater weight] -80g / -2.8oz
    [Others]
    Exposure control: TTL, Manual(Light-level control)
    GN 0.7/1/1.4/2/2.8/4/5.6/8/11/16/22/32 (12 steps)
    - Pre-flash control: Equipped with pre-flash cancel mode
    - Slave function
    - Sync cord: 5-pin Sync cord/N17100, Fiber-optic Cable (L-type
    - Over-pressure relief valve
    - LED target light
    - Test flash function
    - TTL / READY confirmation audible signal
    *1 Number of flashes and recycle time depends on the battery brand, temperature and frequency of use. *2 Number of flashes and recycle time of Ni-MH batteries were tested on 2700mAh batteries.
    Special Instructions
    • We are unable to offer refunds.
    • Bidding for Good provides a service to philanthropic endeavors. They provide a non-profit friendly auction platform, and vet participants so that bidders are confident that they are bidding for an item that will support a verified effort. Unfortunately, this service adds an additional 6% on to every bid. Sea Save Foundation will pass this cost on to bidders so we can maximize our fundraiser. Please note that 6% will be added on to all winning bids.
    • Credit Card Purchases will be levied with an additional 3% to cover costs. Winners interested in avoiding this extra fee can pay by check.
    E-mail diveireland@aol.com or call 831 915 5510 for additional information.
    E-mail earthimag@aol.com or call 310 458 0700 for additional information.
    Edited by adamhanlon
  2. Aquatica HD Underwater Video Housing - Sony Wave CX560 / 700CX
    View Auction at,
    Key Features
    Solid Construction
    Precision machined from a solid block of marine grade aluminum giving endless durability. Black anodized for corrosion protection and a final layer of tuff textured military grade polyurethane powder coat paint for the outmost
    durability in harsh sea water.
    Stable-Wide®
    Our new Stable-Wide comfortable grip system will give the user the most stable underwater balance for optimal solid filming.
    30°Angled Large 3" LCD Viewfinder
    A first in the industry to implement this design for optimal viewing position & filming underwater.
    Reliable all- Mechanical Controls
    Ergonomically positioned controls for easy access to most all key camcorders functions, including Manual White Balance control.
    Full Camcorder Control
    Using the Sony remote commander in the housing will allow full use of camcorder controls underwater.
    30% smaller than
    previous HD-Wave
    Specifications:
    Construction:
    - Marine grade solid aluminum
    - Fully anodized with a hard coat of polyurethane paint
    - All hardware is marine grade aluminum & stainless steel
    Controls:
    - On/Off
    - Record/ Standby
    - Photo
    - Zoom Telephoto / Zoom Wide
    - ALL MENU ACCESS TO ALL CAMCORDER FUNCTIONS
    - Manual Control Knobs to access Focus, Exposure, AE Shift & WB Shift
    Features:
    - Flip filter Arm with UR Pro blue water color correction filter
    - Sensitive Hydrophone to capture clear underwater sound
    - Water sensor alarm with blinking LED
    - Bayonet Mounted Lens System
    - Auxiliary port
    Ports:
    - Wide angle port: (INCLUDED AS STANDARD LENS with housing)
    - A good all around performance lens giving about 90°FOV with full zoom through capability.
    Dimensions:
    - 8.25" D(with lens) x 4.6" H x 9.2" W (14.9"with handles)
    - 21cm D(with lens) x 11.7cm H x 23.3cm W (37.8cm with handles)
    Weight:
    - On land 6 lbs (2.72Kg) fully loaded w/camera battery and lens.
    - In seawater slightly negative buoyancy
    Operating Depth:
    300 feet / 90 meters
    Contact,
    OR
  3. Extreme Action - Recsea XTC100 Midland camera and housing
    Recsea XTC100 Midland housing, which is depth rated to 300 feet. Featuring magnetic controls to compliment the camera.
    View Auction at,
    Contact,
    Jay
    OR
    Georgienne
  4. Dynamic Sola Dive Light by Light and Motion
    View Auction at,
    Sola Photo 600; its the lightest, brightest and one of the smallest focus lights available. The bank of red LEDs adds stealth for catching shy critters and fish.
    Sola photo lights have a factory sealed body so you never need to worry about flooding. A magnetic coupled tap switch instantly flips between red and white mode or increments power levels.
    Three indicator lights behind the bezel report the power and battery charge status.
    Multi-voltage charger interchangeable blades and external wet connection gold plated charge pins for long life.
    Built-in lithium-ion battery is charged through external charge ports with gold plated receivers for years of use. You never need to remove the battery and charging is easy and fast on beach or boat.
    Lumens:
    High- 670
    Med- 335
    Low- 165
    Red: 225
    Run Time:
    High- 80 Min
    Med- 160
    Low- 320
    Red: 200
    Charge Time:
    150 Minutes
    Size & Weight:
    57mm x 101mm &
    283 gr. w/ Ball Mount
    Contact,
    Jay
    OR
    Georgienne
    Edited by diveireland
  5. Dynamic SEA&SEA -YS110 Alpha Strobe
    View Auction at,
    The YS-110 alpha introduces numerous new exciting functions, opening a whole new digital generation.
    1. By connecting it to digital cameras with pre-flash function using a fiber-optic cable, the YS-110 alpha can be used in the fully automatic DS-TTL adjustment mode (Digital Slave TTL).
    2. Enjoy complete creative control when you want absolute control over fine light adjustments. You can use a main strobe in DS-TTL mode and a secondary strobe in manual mode or you can set up an advanced lighting setting using two strobes in DS-TTL mode.
    3. The DS-TTL adjustment function is also available using the light level control dial for fine control of the light amount when taking pictures in DS-TTL mode. You can also choose from 13 levels of manual controls when you do not want to leave the light adjustment up to the camera.
    4. The flat, round, 105° beam angle (with diffuser), achieved by the balanced positioning of the 3 flash tubes, and the power of a Guide Number 22 are examples of the excellent performance of the strobe that is sure to satisfy even the most demanding professionals.
    Specifications:
    • Guide Number (ISO 100/m)(land): 22
    • Beam Angle: 105°x 105°(with diffuser)
    • Batteries: 4xAA; A:6V; Ni-MH: 4.8V
    • Number of Flashes *1: A:230: Ni-MH: 330 Recycle Time (full) *2: A:2.5s; Ni-MH: 1.9 sec.
    • Color temperature: 5400K
    • Color temperature w/diffuser: 5100K
    • Depth rating: 60m / 200ft
    • Dimensions(WxHxD) : 88x115x150mm / 3.5x4.6x6inch
    • Weight: 700g / 24.5oz
    • Underwater weight: -10g / -0.4oz
    Others:
    • Exposure control: DS-TTL, TTL, Light level control dial (GN): 1.4 / 2 / 2.5 / 2.8 / 3.5 / 4 / 4.5 / 5.6 / 6.7 / 8 / 11 / 16 / 22 (13 steps)
    • Pre-flash control: Equipped with pre-flash cancel mode
    • DS-TTL function
    • Auto power OFF function
    • Sync cord: Sync cord/N, Fiber-optic cable (L-type)
    • Over-pressure relief valve
    • LED target light
    • Contact,
      Jay
      OR
      Georgienne
  6. DIVE SAFETY JUST CHANGED FOREVER! Two (2) Nautilus Lifeline NL1 GPS Radios are included
    View Auction at,
    Auctioning two (2) of these state-of-the-art radios. The Nautilus Lifeline is a waterproof VHF radio for divers with emergency Digital Selective Calling (DSC) transmission. In an emergency, the distress button will transmit the divers GPS location and distress message to all vessels within an 8 mile range. Use the orange button to communicate on VHF channel 16, the universal hail and distress channel. Use the green button for non emergency voice communication to your main vessel or other Nautilus Lifeline users within a 4-5 mile range.
    Description Nautilus Lifeline NL1 GPS Radio for Divers
    Red Distress Button: Depress button for 3 seconds for DCS transmission of distress message and GPS coordinates to other vessels within 8 miles (12.5 km) range. Or activate optional non-emergency group call with GPS coordinates and automatic channel switch for all Lifelines belonging to a specific diveboat or group.
    Orange Boat Button: Press this button for voice communication on Ch16, the universal hail and distress channel worldwide on EVERY marine radio. Use this button to select alternate channels 09, 14 or other user pre-selected channels. Imbedded software prevents inexperienced users from inadvertently locking the channel up.
    Green Chat Button: Press this button to chat with your main vessel or other Nautilus Lifeline users on the VHF channel of your choice. Divers can now easily give or receive simple instructions without returning to the main vessel.
    Strobe Light: We prefer to call this the diver position indicating light. Dual strobes will flash in DISTRESS MODE which is especially useful after sunset.
    Waterproof Housing: Tough Polycarbonate housing depth rated to 425 feet (130 meters).
    GPS: Latest version Jupiter 3 GPS receiver displaying latitude and longitude on LCD display.
    LCD Display: Displays GPS signal lock, GPS position, signal lock, channel in use, battery remaining as well as volume, squelch, channel selection and GPS polling.
    Clip: Designed to conveniently and securely attach to a D-Ring.
    Speaker / Microphone: Waterproof to IP67 standards. Submersible to 3 feet (1 meter). The cap of your Lifeline can be opened on the surface (only) in any sea state allowing full use of all features.
    USB Port: Used for recharging the battery, or interface for adjusting advanced settings.
    Contact,
    Jay
    OR
    Georgienne
