Ikelite 5050 and D-125 strobe
Started by Lionfish43 ·
  1. Ikelite 5050 and D-125 strobe
    A good friend of mine is considering purchasing this system and he posed this question to me:
    The Ike DS-125 (needed for WA shoting) comes with either a TTL sync
    > cord, a manual controller (which operates as a slave unit or can be
    > synch cord connected, or a TTL sensor. What would you recommend. I
    > have never used any kind of sensors in the past other than a TTL
    > setting on the Nikonos SB105. I presume the TTL sensor has an on/off
    > switch so that when you use the internal flash in the Olympus camera,
    > the external TTL sensor is not operative.
    > Also, should I lay hands on this gear before I ship out, is there a
    > book you recommend that will educate me as to digital U/W shooting?
