Strobe Sync Speed with Canon 600D/ Nauticam
Started by gee13 ·
  1. Hi All
    Just wondering if anyone who has been using the 600D have experienced or awware of an issue with this. I hear its only 1/180 and wondering how this would compare with the 60D or 7D and how much I would impact on particular uw photos.
  2. Hi All
    Hi,
    The flash sync shutter speed of 600D is 1/200; and that of 60D and 7D is both 1/250. I don't think you will experience substantial difference due to the slightly slower flash sync shutter speed. By the way, the following galleries are both shot with external strobes set to S-TTL:
    http://nauticam.smugmug.com/HousingTests/N...19585418_sggxZP
    http://nauticam.smugmug.com/HousingTests/N...18395590_FSqtWd
    Edward
  3. Hi,
    Edward
    Hi Edward I currently use an S90 in fix housing with S2000s How does this compare in terms of strobe sync speed for the 600 D?
  4. Hi Edward I currently use an S90 in fix housing with S2000s How does this compare in terms of strobe sync speed for the 600 D?
    Hi Gee,
    The minimum strobe sync speed of S90 is at 1/500 sec. Although this looks to be faster than the 600D, but coupled with the smallest aperture limit of F8 I think you are going to achieve better background brightness control with the 600D.
    Another shortcoming of the S90 is that when you set to M(anual) mode the camera flash does not provide TTL, while the 600D does. We found the TTL of 600D worked quite well with external S-TTL or DS-TTL compatible strobes, even for wideangle shots.
    Best regards,
    Edward
