Dynamic Sola 600 Light by Light and Motion
Started by diveireland ·
  1. Brand New! Dynamic Sola 600 Light by Light and Motion
    Current Bid is $370
    At.
    https://www.biddingforgood.com/auction/item...on?id=145441475
    Sola Photo 600; its the lightest, brightest and one of the smallest focus lights available. The bank of red LEDs adds stealth for catching shy critters and fish.
    Sola photo lights have a factory sealed body so you never need to worry about flooding. A magnetic coupled tap switch instantly flips between red and white mode or increments power levels.
    Three indicator lights behind the bezel report the power and battery charge status.
    Multi-voltage charger interchangeable blades and external wet connection gold plated charge pins for long life.
    Built-in lithium-ion battery is charged through external charge ports with gold plated receivers for years of use. You never need to remove the battery and charging is easy and fast on beach or boat.
    Lumens:
    High- 670
    Med- 335
    Low- 165
    Red: 225
    Run Time:
    High- 80 Min
    Med- 160
    Low- 320
    Red: 200
    Charge Time:
    150 Minutes
    Size & Weight:
    57mm x 101mm &
    283 gr. w/ Ball Mount
