For Sale Sea&Sea DX-D50 Housing + Nikon D50 Camera
Started by langusten ·
  1. ++Sea&Sea DX-D50 Housing + Nikon D50 Camera++
    Excellent condition !!!
    never flooded !!!
    Sea&Sea Housing and Nikon Camera
    Perfectly good working order !
    Housing with customized connector, see photo !
    With customized connector work TTL Converter !
    includes:
    New O-Ring set Slicon Tube
    Instruction Manual
    O-Ring Remower
    Shipping with Track&Trace and insurance
    Europa and England 30,00 Euro
    Worlvide Shipping 50,00 Euro
    DX-D50 Housing
    • Smaller, lighter D50 camera enabled a smaller, lighter housing. The camera fits custom-designed snug, contoured for maximum maneuverability.
    • The front case is constructed of rugged corrosion-resistant aluminum alloy.
    • Incorporates a 0.66x optical viewfinder, with corner-to-corner clarity of the camera's data.
    • Redesigned shutter release lever is ultra responsive and communicates fluidly with the camera.
    • Compatible with the full range of SEA&SEA NX ports, gears and accessories.
    • Enables use of all the essential Nikon D50 camera functions underwater.
    • The quick shoe facilitates quick and easy camera-to-housing installation and removal.
    • Fail-safe port locking mechanism prohibits accidental loosening of the port.
    • Comes standard with two 5-pin N-connector strobe bulkhead connectors.
    • Three locking latches provide triple protection against accidental opening of the cases.
    • Built-in leak sensor warns in the event of moisture penetration.
    Specifications
    • Construction: Front case: Corrosion-resistant aluminum alloy; Rear case:
    • Polycarbonate; Grips: Corrosion-resistant die-cast aluminumDepth rating: 60m / 200ftDimensions: (WxHxD) 320x183x135mm / 12.5x7.2x5.3inch
    • Weight: Approx. 2,500g (housing only) / 87.5oz
    * Although the image shows a single strobe connector, the DX-D50 is equipped with two strobe connectors.
    * Specifications subject to change without notice.
    merit_01.jpgThe configuration of function buttons makes them easy to reach and operate.
    merit_02.jpgThe new and improved shutter release lever makes it easier to press "just halfway" to fix the subject in focus. A light follow-through of pressure takes the shot.
    merit_03.jpgWhen the focus mode is set to M (manual), turn the focus / zoom dial to adjust the point of focus. Can be operated while holding the grip. Enables fine focus adjustment without taking your eye from the viewfinder.
    merit_04.jpgThe AE/AF lock lever is used to lock the automatic focus. Logically located to be accessed while holding the grip.
    merit_05.jpgLocking latches on both sides and top of the body are of noncorrosive stainless steel. Special safety lock design prevents unintentional release.
    merit_06.jpgLocated topside where you can see them at a glance, the power switch and exposure compensation button. Simply press and turn the exposure compensation button to set in the down position, operate the command dial with the other hand.
    merit_07.jpgThe focus mode dial can be operated underwater. Allows you to change between AF and M.
    merit_08.jpgThe buttons on the rear case communicate with camera for a plethora of functions: single/continuous shooting, replay, menu, thumbnail display, help/protect, and execute.
    Edited by langusten
