olympus 5060 + ikelite DS125
Started by arving ·
  1. olympus 5060 + ikelite DS125
    The new olympus housing PT20 has a TTL flash connector. Does it mean that I can use sync cord to connect it to Ikelite DS125 strobe and have TTL flash?
  2. No, you need the special Olympus sync cord and can only connect it to the Olympus flash housing for their small land flash.
    Hopefully in the future though...
    HTH
  3. Is Ike planning to produce a sync cord for PT20?
    I don't mind the TTL function because most of the time I will use manual setting. But I hate the cordless sensor. It is too big and not convinence when I mount it on the frame.
    I prefer Sea & Sea optical cord but I like Ike DS125. I don't know how to make the decision. Please give me some suggestion.
  4. Ikelite TTL system for the 5060 will only be available in the rugged Ikelite housing as one of its several advantages. Believe we can make the optional Olympus wide angle lens more user friendly in a special dome port for example.
