Borrow a Fathoms 90 port for Bluefin HD?
Started by echeng ·
  • 9Posts
  • 9Replies
  1. Hello, all. I'm looking to borrow or rent a Fathoms 90 port for a Light & Motion Bluefin HD housing from January 16 to February 4. If someone has one and isn't using it during that time, please let me know your terms.
    Thank you!
  2. Hello, all. I'm looking to borrow or rent a Fathoms 90 port for a Light & Motion Bluefin HD housing from January 16 to February 4. If someone has one and isn't using it during that time, please let me know your terms.
    Thank you!
    For a Sony CX camcorder? I have one, here in Singapore.
    Where do you plan to use it?
    Regards
    Peter
  3. For a Sony CX camcorder? I have one, here in Singapore.
    Regards
    Peter
    Hey Peter
    I somehow knew you would chime in - LOL.
    Hey Eric
    If you want to borrow one for Canon BF I have the 90 deg (also the older Canon BF version) and the wet attachable 65deg version. I have also made a custom magnetic flip with +2 dioptre and that works with the 90 deg Fathom the only draw back is it then needs a 120mm ext red filter for wide shots. Small inconvenience for a lens for all types of shooting conditions.
    David
  4. Thanks, guys. :)
    It's for Bluefin HD for Canon XA10. And I'll be coming through Singapore, too. :)
    Is a Bluefin HD a Bluefin HD, or is there a different ports for Sony and Canon?
    David, what is a Canon BF?
  5. Thanks, guys. :)
    Canon BF= Bluefin HD for Canon XA10 or HF G10..... abbreviating is a bad habit of mine :(
    Yup Light and Motion housing have different Fathom lenses for Sony and Canon camcorders. L&M (i am abbreviating again) only have Bluefin housings for Canon now. Sony CX700 or 560 is not supported due to the changes made by Sony on the electronic user interface and the final nail in the coffin is the MBW and as far as I know only available on the touch screen and Sony remote. Mechanical housings maybe okay but not electronic.
    David
  6. Hey Eric,
    I have one for the Blufin for an A1-U and another for the Canon HFS-10 that I haven't used in ages. You are welcome to borrow either.
  7. If you want to borrow one for Canon BF I have the 90 deg (also the older Canon BF version) and the wet attachable 65deg version. I have also made a custom magnetic flip with +2 dioptre and that works with the 90 deg Fathom the only draw back is it then needs a 120mm ext red filter for wide shots. Small inconvenience for a lens for all types of shooting conditions.
    Thank you, David! I will take you up on your offer and try to arrive with a full Bluefin setup. :)
  8. Thank you, David! I will take you up on your offer and try to arrive with a full Bluefin setup. :)
    Cheers Eric
    See you in a few days.
  9. Sony CX700 or 560 is not supported due to the changes made by Sony on the electronic user interface and the final nail in the coffin is the MBW and as far as I know only available on the touch screen and Sony remote. Mechanical housings maybe okay but not electronic.
    David
    Yes the changes from sony are causing housing reprogramming, for those who can do it. CX700 white balance or any feature is available via menu navigation using scripting. This is confirmed for Ir-remote and i think is doable via lanc. Ive seen sample lanc menu navigation so im assume enough of that is there for that to work too. Im the wrong person to compare wb, since the cx700 my first white balance camera, but is powerfull.
