SOLAR 800 charger power plug issue?
Started by ocean2 ·
  1. i have purchased the light&motion sola 800 photo light from the states and am from australia and foolishly forgot about the different power plugs and supply for the charger is it safe to use a U.S to Australian adaptor on the U.S plug attached to charger being different power levels 110v-240v or will i have to send it back or buy another charger and if another charger where can i buy one?
  2. Most charger are rate for 100v to 240 v (50/60Hz). It should be indicate on changer. if so you don't have to worry and can use U.S to Australian adaptor.
  3. PM sent
