FIX Fisheye Aluminum Housing TEK 100 for Canon G10
Started by waterloggedimages ·
  1. FIX Fisheye aluminum housing TEK 100
    The housing is in great condition, normal paint wear, no dents, no major scratches, well maintained. Also comes with ultra-light twin handle tray with an optional ultra-light ball mount on housing for extra lighting. I am also adding a port adapter to allow you to screw on a diopter. (diopter not included) This allows you to remove the diopter underwater for different photo opportunities. The housing also has two fiber optic plugs for external strobes. (strobes and fiber optic cables not included) I have $2000 invested, will sacrafice for $700.00.
    Detailed FIX Fisheye underwater housing item info
    Fisheye Housing for the Canon G10 Camera. Fisheye has scored another big hit with their all new housing for the Canon G10 camera. This small ergonomic housing is perfect for the traveler who wants to keep their system light and simple!Fisheye FIX G10 Housing for Canon G10 Camera
    The machined aluminum Fisheye FIX G10 housing is the perfect match for the 14.7MP Canon G10. It fits the camera like a glove and offers 100m depth rating. Housing ergonomics are great with or without a handle and the removable port allows installation of a 15mm wide angle lens.
    Unlike many compact cameras on the market, the Canon Powershot G10 offer full manual camera controls. New users can shoot in automatic mode, but the manual control option means they won't outgrow the camera. The Fisheye FIX G10 housing gives the user full access to all essential controls.
    Construction: Machined aluminum with hard black anodized finish
    Weight: 810g / 1.78 lbs.
    Size: 142 x 123 x 116 mm / 5.59 x 4.84 x 4.57 in.
    Depth Rating: 100m
    This is the deeper version TEK 100
    Rated to 100 meter, the optional deep water version comes with stiffer springs, an aluminum front port and is tested to 120 meters.
    The TEK 100 is the upgraded model that comes with the aluminum port, compared to the standard port which is plastic. It also has stiffer springs in the controls.
    MESSAGE ME FOR COMPLETE PICTURES. THANKS!
    Edited by waterloggedimages
  2. I am interested, can you send me pictures?
