Metering Mode Canon 7D
Started by Robotpimp ·
  1. I plan to photograph Great White Sharks from a cage in the next couple of weeks. I have a Canon 7D with a Nauticam housing. I've been using the camera on land set to Evaluative Metering and was wondering whether I should continue with this setting for the shark shoot or if one of the other metering modes would be better suited?
    All lighting will be natural and I'll be using a Canon 10-22mm lens with a Nauticam 8.5" dome port.
    Any advice is appreciated.
    Regards,
    MJ
  2. I plan to photograph Great White Sharks from a cage in the next couple of weeks. I have a Canon 7D with a Nauticam housing. I've been using the camera on land set to Evaluative Metering and was wondering whether I should continue with this setting for the shark shoot or if one of the other metering modes would be better suited?
    Regards,
    MJ
    Evaluative is a good starting point. Remember the water is often darker then mid-grey, so a little minus exposure compensation will help... around 1/2 stop (or 2/3 stop if you're using thirds) will be good.
    darren
