Beginner Setup
Started by Eagle ·
Beginner Setup
  1. I am just starting out, already have an Olympus XZ-1 in a Olympus housing and am looking to add a strobe on a small budget. Can anyone suggest if it would be better to go with 2 cheaper, manual strobes or upgrade to 1, maybe more powerful strobe with TTL? Any suggestions?
    Edited by Eagle
  2. Depends on what you mean by cheap. I would go for 2 s2000's by Inon. Great macro and wide coverage for you there.
  3. Was looking at the Inon S2000. However that would be for a single strobe setup. Was thinking possibly 2 Bonica G8-B's. Or the Intova ISS 4000 seems to be the same strobe. Anyone have any feedback on either of these?
  4. Stick with the Inon or Sea&Sea YS01, if you can afford it the YS110a is strobe that you would keep through several upgrades in cameras.
  5. Sooner or later, you will want 2 good strobes based on your comments. If you buy one good one now, you are 1/2 way there. If you buy a cheap pair, you are still 100% away from your goal. I just finished a trip and worked on taking photo's with one strobe (while having 2 present). You can do a lot with one good strobe.
  6. I'd also opt for one good strobe now and add another later. Learning how to add strobe light to the ambient can be tricky and doing it with one strobe first makes the process less complicated. Besides, you will also learn when sometimes less is more - even with strobes!
    Lee
