DS161 don't work at F and -1/2
Started by marc1990 ·
  1. I have two DS161 with dual sync cord. When I set strobe control in my house(ikelite 7D) at TTL and set strobe to manual only -1 and lower work. Full and -1/2 does fire but to early.
    When I set housing to manual i can set them both manual I can use the full range.
    But I want one manual strobe en one TTL.
    Do more people have this problem?
  2. i am pretty sure that if you ask Ikelite they will say that the housing has to be set on manual. Think i had a similar question once. The only way you can have one TTL and one manual is when you use a wireless solution.
