Nauticam port 50 /w 1.4x teleconverter?
Started by Fpena06 ·
  1. Hello everyone,
    I currently have the following.
    Nikon D300s
    Nikkor 105mm
    Nauticam NA-300s
    Nauticam Port 50
    Can I use a 1.4x teleconverter with this setup without having to purchase port extension? If not what port extension will I need?
    Thank you in advance!
    Edited by Fpena06
  2. Hello everyone,
    Nikon D300s
    Nikkor 105mm
    Nauticam NA-300s
    Nauticam Port 50
    I believe you will need 20cm of extension (assuming the port you mention is the "Compact Port 50") (and assuming you are talking about a teleconverter with about the same dimensions as the Kenko 1.4). You could use either an "Extension Ring 20 with Lock" or a "Compact Port Extension 20". Note that if you have a manual focus ring, it won't work with the TC attached.
    Cp
  3. I believe you will need 20cm of extension (assuming the port you mention is the "Compact Port 50") (and assuming you are talking about a teleconverter with about the same dimensions as the Kenko 1.4). You could use either an "Extension Ring 20 with Lock" or a "Compact Port Extension 20". Note that if you have a manual focus ring, it won't work with the TC attached.
    Cp
    Thanks Cp very helpful! Any benefit for one or the other? Notice a bit of a price difference between the two.
    Edited by Fpena06
  4. Thanks Cp very helpful! Any benefit for one or the other? Notice a bit of a price difference between the two.
    The Extension Ring 20 would be useful for other port combinations (example: 8.5" dome and Tokina 10-17mm). The Compact Extension is a tiny bit lighter (good for travel) and cheaper (good for wallet), but would be mostly useful for this one purpose only and is a little more of a pain to swap out.
    Cp
  5. The Extension Ring 20 would be useful for other port combinations (example: 8.5" dome and Tokina 10-17mm). The Compact Extension is a tiny bit lighter (good for travel) and cheaper (good for wallet), but would be mostly useful for this one purpose only and is a little more of a pain to swap out.
    Cp
    You sold me when you mentioned the 10-17 :lol: my next lens. Thanks again.
  6. I believe you will need 20cm of extension (assuming the port you mention is the "Compact Port 50") (and assuming you are talking about a teleconverter with about the same dimensions as the Kenko 1.4). You could use either an "Extension Ring 20 with Lock" or a "Compact Port Extension 20". Note that if you have a manual focus ring, it won't work with the TC attached.
    Cp
    I guess that it should be 20 mm of extension :lol:.
